trbomax
- Joined
- Oct 16, 2014
- Messages
- 981
The converter is what makes most of the heat unless it is locked up.
Why would you not want the converter to lock up? That is a good way to overheat your transmission.
I learned something. Also got a little concerned that my 'plan' wouldn't work.
With a 3:31 rear towing my upcoming purchase of a 27' Hyperlite my plan was to barely use 6th gear on the open road.
I was concerned about the constant locking and unlocking of the clutches in the Torque Converter (TC) and about the constant down-shifting from 6th to 5th and back up. Which, in my experience is fairly common on the older trannies and leads to them going up in smoke.
Turns out that --
6R80 Specs & Ratios - F150 Hub
6R80 Specs & Ratios
It features torque converter lockup capabilities in all 6 gears
BT:
Hope that's true because I don't believe I will be able to handle 6th gear lockup with all that resistance behind me
It doesn't show what your tv is but I have the 3.31 ratio in my Eco work truck and towed my 9000 pound crossroads with it from BC to Calgary. It had no problem holding 6 th on the flats on cruise control. GCW was 14,900, rated at GCWR15,100. Have to say it towed it better than my 2500 sub with a 7.4 L.
Am I correct in thinking the 2019 f150 3.5 has a 3.55 rear end?
In my opinion, no. I tow with a 2012 Yukon XL Denali and have made significant upgrades to the cooling system, including a fan-forced Derale transmission cooler. I often see temps on steep climbs over the mountains of 235ºF pulling a 7,000 lb camper. Your Silverado already likely has the factory external transmission cooler and 215ºF is perfectly fine for the 6L80E. In my opinion having studied this issue to death, it would be a waste of money in your case.I tow with ‘13 Silverado 1500 6 speed. Going up long, steep grades towing my 3000# trailer here in the Sierra mtn’s my tranny hits 215*. Should I put an aux. trans cooler on it?
Also, would a free flowing muffler help? I ask because a local muffler shop said the stock muffler has 12# back pressure and the Magnaflow they recommended has 3# back pressure and it would make a big difference in the tranny temps.
There is no muffler that has any effect what so ever on a transmission.
Furthermore any power increases put into a vehicle of any kind only serve to likely raise the temp of engine and trans. For the most part the efficiency of eternal combustion engines is rather fixed. So adding power generally means adding more fuel so more fuel burned means more heat created.
Too bad the simpletons who say and feel other wise just couldn't use their heads and think.
That post you're referring to is over 15 yrs old, so yeah it would be out of date.That initial chart is woefully out of date. My F350's normal temp is 205. Times have changed.
And my F-250 will be 20 years old next year. A lot of us have perfectly good old trucks so works for us.That post you're referring to is over 15 yrs old, so yeah it would be out of date.
Fords with the 10 spd run hot, so 205 being normal for you is not normal for my Ram Aisin that has a normal temp of 160°.
