Trying to identify connector on WFCO Inverter
2RossDogz
RV LIFE Pro
Mar 11, 2025
3
I am putting a LiFePO4 battery in the storage compartment of our Rockwood MiniLite and want to disconnect the existing pos/neg cables and use new cables. Does anyone know where to purchase these kind of connectors? I have reached out to WFCO and have not received a correct answer. The attached photo is of the two connectors on a WF-5318 Inverter. Any help would be appreciated.
try calling WFCO
they usually answer and are happy to assist
I'm almost positive you are looking at a rubber or plastic boot/cover that protects the 12v lugs for connecting the DC feed wires, not a specialized connector. The boot/cover is slipped over the DC wire before the wire ring connector is bolted to the lug, the connection is then torqued per spec, then the cover moved forward to protect the metal from unwanted contact. This may be more evident if you can look up inside the connection.
I believe you are correct. I also heard back from WFCO with the same response. Will be checking it out today. Didn't want to go poking around with power on, so will disconnect batteries and shore power and check.
Thanks!
I was able to confirm that it is just a boot around a standard terminal. This will make getting new cables much easier! Thanks for the help!
