Iggy,
Be careful with that grease you bought from Walmart. It has a drop point 90 degrees below the minimum spec by AL-KO.
It has a drop point of 350 degrees minimum.
That is what the label says.What do you use?
Iggy,
Iggy,
Thanks for your input.
Took the grease back and found the stuff I needed.
How is the specs on this one.
The tube says not to mix different types of grease, how do you know if it is compatable with what is in there already?
I'll probably get flamed for saying this but here goes......
We're talking about grease and wheel bearings.
Not changing the oil in your engine.
As far as I'm concerned, grease does not normally wear
out. As long as it's not contaminated or very old it's
going to be fine.
I for one am not going to try to "flush" out my hubs every
year. Just not gonna do it. I changed bearings and seals
last spring and I'm satisfied they are as full of new grease
as can be so I'm done for a couple years.
After that I may pump some new stuff in there from
time to time but I'm not going to try to run a half
cartridge thru the fitting!
My 2¢
Oh yeah, bearings are "color blind"
I am going to be doing mine when enough snow melts to get it out of storage. Was wondering if I had to worry about the new grease being compatable with what is in there. I like the idea of the different colors so you know the new grease has filled the color blind bearing.The color of the original grease from the factory is black and this new stuff is red. It is all Class 2 grease and all you are doing is flushing out the lines and the bearing races until you see all red grease.
Is that what you are looking for?
I WOULD BE CAREFULL / CHECK W/ MANUFACTURE
TO MUCH GREASE IN HUB WILL EASE OUT TO THE BAKES
CAUSING THEM TO FAIL
