Anyone have a retractable one ?
I had one on a first gen Colorado. Worked pretty well but the "can" where the cover rolls into at the front of the bed takes up room in the bed.
I can't see how it's attached to the rails. Is it secure against theft?I have a BAK Revolver aluminum roll up cover....I like it![]()
Retrax Pro. Also solved the problem of carrying bikes with the TT while towing.
Although, neither the Retrax Pro nor my prior Encore Extang were completely watertight. And gets worse when you park off level.
Also, $$$.
A very flexible cover, since it can lock in any position.
No. The canister - mine anyway - is only about 8 inches by about 7 inches, so it uses about 7 inches of space into the bed (measured from the top of the bedrail). I still have 12-13 inches of space under it so the full length of the bed is still usable there. I can fit a few dozen sheets of sheetrock or plywood under the canister or a whole bunch of lumber.I don’t carry much in the bed but I assume it will make a 4.5’ bed outta my 5.5’ bed ?
What crossbar system & bike racks are you using on yours? Happy with them?
I've been looking at the Rhino Rack Vortex with Thule ProRide or UpRide
Did the same setup and love itRetrax Pro. Also solved the problem of carrying bikes with the TT while towing.
Also, $$$.
So the advantage of the Revolver over a BakFlip is that it doesn't block the rear window when the bed is open?The rails are clamped in the bed
Yes, that is the only advantage as far as I can tell. I went back & forth between a Bakflip & the Revolver and chose the roll-up for that reason.
I own a Bakflip, and you can. With only one panel open, the panel lays flush on the one behind it. I've never felt a need to secure it. I just did that today, carrying a ladder.X2.....Not sure if you have a Bakflip if you can keep one or two of the panels open with out having to open all the panels while driving down the road ....On the Revolver you have to open it all the way to secure it it.
