I replaced the 4 leaf spring packs with 6 leaf to raise the 5er a couple inches. That worked and to be honest, the 4 leaf were flat as pancakes and seemed undersized to me anyway.
When I consulted everyone on here when doing that, I vaguely remember someone mentioning I should upgrade the hubs/bearings as well. Well, now I want to do that.
I looked at the Dexter parts catalogue and it appears the hub/rotor assembly is different between the 5200 lbs and 6000 lbs axles. Also the 6000 lbs axles have 15123 outer bearings but the same inner bearings.
My question: do I need new hub/rotors or just the new 15123 bearing?
And to be clear, I am 900 lbs under on axle ratings with a fully loaded trailer. I do not want to increase the axle ratings. I just want margin. If the bearings are working as hard as the 4 leaf packs, that doesn't sit well with me.
