Installed my VHF radio we use for my race team in the DX3. Installed one head next to the CB and the other in the area with the outside TV. Both go back to a single radio. Wire routing since it’s on the slide was especially challenging. But it came out Very trick! Antenna is on left mirror with a clamp on, however since I’ve done this I found the part number for the same bracket used on the driver side CB antenna. Would have used that if I knew it.
The actual radio is mounted in the cabinet that’s on your right side next to the stairs.
—john
—john
