Tonyyoknee
- Joined
- May 18, 2024
- Posts
- 5
I apologize if this question has been asked multiple times in advance.
I have a 2023 flagstaff 19 BH E Pro, and would like to utilize a smarter battery monitor than what is in the trailer. In looking on where the shunt placement goes between the battery negative post and all other loads. I see that my negative load side on the trailer is traced back to the inverter.
When the shunt is in place it only will show battery voltage and % charge on the app and the small monitor screeen. With it not connected to shore power and inverter is turned on I get current, power, consumed Ah and Time remaining.
If I shut off the inverter I only get battery voltage and %. Is my (-) load side incorrect? and not the inverter? Is it behind / near the converter.
Moved battery bank inside next to inverter (-) load
