I hate to keep beating this horse, but have you read the tutorial? You still don't sound like you are understanding the difference between what controls what mode of heating for the water heater.
Is it possible that I did read it and do understand, but have a particularly vexing problem at hand?
I did read the tutorial. What I'm telling you is, this...
When I turned on the red switch on the Puma panel, the water heater came on with gas.
About 5 minutes later, it tripped the shore power breaker again.
I turned off the 15 amp water heater breaker inside the trailer and reset the 30 amp shore breaker, and now it won't heat with gas, and the fault light is on.
I have tuned off the switch and turned it back on to try to "reset" the fault light, but it won't go off and the water heater is not heating.
I have to leave the 15 amp water heater breaker off, or else the 30 amp shore breaker trips. With the 15 amp internal breaker off, nothing happens, but I don't have hot water, because nothing happens.
If I turn on the 15 amp breaker, it WILL run on gas, but I presume it's also running on electricity and when the water gets hot, it trips the shore breaker.
The 15 amp internal breaker never trips. Only the 30 amp shore breaker.
It seems to me that the shore breaker should NOT be tripping for any reason. It *could* be a weak breaker on the pole I suppose.
Exactly what am I missing?
I'll go read the threads all over again, but I don't think I missed anything. Here's what I understand...
- If I turn off the internal breaker, that should make the water heater run only on gas, because it's the way it'd run if we were out in the mountains away from civilization.
- With the gas on, the switch inside the water heater on, and the "htr" switch on the panel on, it should run on gas and be able to light itself properly.
