2004flagstaff625d
- Joined
- Jun 10, 2024
- Messages
- 22
Hi all!
I recently got a 2004 flagstaff 625d camper. I've gone thru and gotten the 12v system, the shore power, the burners, the fridge, and the furnace all working. Water thru city water works as does the self contained system. I even figured out the toilet.
My last issue is with the suburban brand water heater. This thing is old. It's gas only and uses a pilot light. I can get the pilot lit fairly easily but this thing just will not kick on and actually heat the water.
Temp is set to med-high and water temp is around 50 degrees in the tank. I have a few theories but basically no knowledge about this thing.
Could the gas control unit be clogged up? The pilot works thru it but no main gas.
Could the thermostat be bad? I don't even know how to test it.
I've attached some pics for reference. Any advice or insight is greatly appreciated.
