Larry-NC
TPO is the rubber-like sheet that covers the roof.The factory has just told me that my 37FLL has passed PDI at the factory. They are ready to tow it back down here in Alabama. This is what they said:
I hope this helps someone else who has this same problem. I'm not even sure of what they are referring to. Maybe someone else can translate?pull cap moldings off & TPO moldings & TPO off, replace wood shims for TPO replace TPO & moldings, Inspected upper decking, no signs of water intrusion
Pull cap moldings=> Remove the moldings around the cap
Pull TPO moldings=> Remove the moldings at the edge of the TPO roofing
Pull TPO off=>Pull off the TPO which is cemented down.
Replace wood shims for TPO=>Replace thin wood wedged that were under the TPO. This is good since they were probably water-damaged.
Replace TPO=>Cement the TPO back on
Replace TPO moldings=>Put the moldings at the edge of the TPO roofing back on
Inspected upper decking, no sign of water intrusion=>We looked at the plywood under the TPO and it showed no sign of having been wet.
Does that help?
