Water not filling
Fastfwd101
Apr 28, 2024
5
I have a 2017 F35RGDX, came with 2 fresh water tanks, a 100 gal and a 50 gal. I have a hard time filling them, right now I only have 67 gal in and it’s acting full.
Any ideas out any one has similar issues?
Thanks in advance Eddie
We have a 2016 Shockwave, it holds 160 gallons of water. That's with a 100 and a 60 gallon tank also.
It is slow to fill because the 60 gallon tank is cross fed with a small line. I often times put the fill hose in and turn it on slow and let it run till it runs over. Turning it on slow avoids pressurizing the water tank as it can vent as fast as the water is being put in.
I've never had the occasion to measure the water going in but we can get by for ten days easily with full tanks. That's if we are somewhere we are allowed to do the terrible thing of draining our gray water on the ground. We seldom stay in an RV park, love the great outdoors so we boondocks 95% of the time.
Her bike, thanks for the reply, I too let it fill very slowly. I have a water counter that you can get for cheap at a hardware store. The last time I even towed and shock the camper around with no luck. I drained it and refilled I am now up to 120 gallons. I think there is an air pocket in the smaller tank.
Now you got me curious, I may have to buy me a water meter too.
We did feel like we run short of water last week, when I dumped the fresh water it didn't take long to drain, 1 1/2 inch drain.
I've got to go to town tomorrow, think I'll see if I can find a meter.
I read on a separate FR forum that there are problems with kinks/dips in the lines and vent tubes. The suggested work around was to push a tube or hose against the vent screen and blow. I did it and at first I felt resistance and once I blew a little harder and got past the resistance you could hear the water slosh and then lots of "burping" sounds. The vent spewed water and then I could continue filling the tank all the way.
I actually have been doing this by blowing on the main fill line and does as u say for awhile.
Let me know how it turns out, now I’m curious.
I got the water meter from Amazon this afternoon.
Promptly went out and filled the fresh water tank as we are leaving in the morning for a week of boon docking and play with our Polaris RZR.
Anyway, if the meter is accurate it read 166 gallons by the time I got back out to check it. At 120 gallons it started gurgling as usual because the water was running too fast. I slowed it down and the wife and I were in the shop doing some more preparing. I went out to check it and it was running over, the looks of what was on the ground I'd say the extra 6 gallons was about right.
You may have a kink in your cross over line or the vent line as the former post suggested.
Good luck with figuring it out. Getting into the under belly isn't a fun job.
