water problem
oldnewguy
Feb 21, 2013
230
plymouth ma
Have a 2013 3050s sunseeker, this weekend while hooked to city water, my freshwater tank filled. i know this is a problem that was in a thread before , just can not find it. should be a back flow valve stuck open or broken, just need to know location of valve. thanks in advance for a response
The check valve is usually part of the pump. Replace pump ($$) or 1) find new parts for old pum, 2) add a 2nd check valve on the suction of the pump, or 3) add a ball valve on the suction of the pump. (Check valve if you use the FW tank a lot. Ball valve if you don't.)
Shut off city water
Make sure water pump is off
open faucet
turn on water pump
let water run for a minute
shut off faucet
wait until pump stops.
Shut off pump
turn on city water.
This should reset the back flow valve
X'S 2 on fly boys comment, I have used that about 3 different times, It seems that if my pump is on by mistake and I turn the city water on is when it happens to me, that's all I can figure out, but what Flyboy say's will fix it if you do not have a diaphragm problem....:trink39::us-flag-waving:
