Bill Boltralik
Advanced Member
- Joined
- Nov 17, 2021
- Posts
- 30
I just purchased the Seaflo 56A Series Variable Speed Smart Pump to replace the OEM 2022 Europa 31SS water pump which is quite noisy and in our case cycles way to much with the sink barely running. I have installed this pump on my last two RVs and loved it. The pump just makes a purring noise with low pressure. Amazing water flow. Highly recommended!Anyone found a way to reduce water pump noise?
The pump in my Europa 31 is under the bed. When one person uses the toilet or sink at night time, the pump noise wakes the other person.
Brian C recently made a FB post about an alternative pump being tested (Seaflo 12v 56a variable speed pump). Has anyone tried swaping in this pump?
I know the water pump is under the master bed, but not sure how to get to it. Does any have the instructions on what has to be done to expose the pump? I assume the bedroom slide has to be out. Does the mattress have to be removed? I would sure appreciate any guidance from those who have replaced your Europa 31SS Shurflo pump.
