NXR
- On the very last morning, the day where the next stop was home, I noticed the light over the kitchen sink was flickering. When I looked closer I could see one of the LED segments was flickering while the other was on solid. It, so far, has fixed itself. If it continues to act up I'll probably swap it with one we rarely use.
- While cleaning the windshield just before leaving Florida, I noticed a small ding on the passenger side of the glass. It's about the size of a pen tip. I put a piece of Scotch tape over it because there is a crescent-shaped crack behind it and we were driving into rain and had freezing temps overnight. The whole area is less than 1/2" square. Our "no deductible" glass coverage insurance is having it fixed tomorrow by Safelite. The crack has not gotten larger yet.
- One of the "push nuts", the little circle thingy that pushes up over the bottom of the SlimRack rack pins to hold the pin in place, fell off somewhere. Those must be a metric size and I have not yet found a replacement.
Yup, that's it. We're probably coming up on 330 nights in this thing since we took delivery almost two years ago.
I'm going to have to replace both bathroom faucets, though. The hot water faucets are hard to turn and squeak when hot water flows through them and now the cold water faucets are starting the same thing (but with cold water).
Temps were 22 in TN and KY when we left and as Btm noted, the SlimRack slides never noticed.
If you're ordering a new unit and waffling on whether to get the dual pane windows, do it. In Florida we had no condensation at all. On the way back, when it was 22 overnight, we had a LOT of condensation on the inside of the windshield and the windshield was much colder to the touch than any of the dual pane windows.
Ray
