Mookie58
I am doing my first winterization. I opened the low point drains and drained the hot and cold lines the best I could that way, and then followed up with compressed air via the city water connection to push any remaining water out each hot and cold faucet setting as well as the toilet. I also blew out the Showermise line in the shower. I then turned the supply valve at the water pump to the setting that uses the antifreeze suction port located on the outside of the trailer. I plan to pump and fill the water lines with antifreeze in a day or two. I'll also fill the Showermiser line and allow antifreeze to fill the low point drain lines (pumping a little more antifreeze after in to make up for anything lost through the low point drains).
As I was changing the water pump supply valve position I wondered how I ensure the supply line from the FW tank to the water pump is either cleared with air or filled with antifreeze. Did I miss a step somewhere? Thanks for any help offered!
