Winterizing
Wheely82
RV LIFE Pro
Oct 11, 2024
2
Hello folks,
New to RVing and I have a 2023 Rockwood 2614bs 30ft travel trailer.
What is the positions of the hot water tank for winterizing and also where is the water filter located?
Thanks for the help
You should either have 2 or 3 valves behind the water heater they need to be set to bypass the water heater. Search the site some pictures are available.
As far as the water filter are you sure that you have one?
Others should be along soon with more assistance.
:signhavefun:
This post does a pretty good job explaining the different types of valve setups you might have and how to set them with pictures.
https://www.forestriverforums.com/forums/f217/no-or-lukewarm-hot-water-please-read-first-103381.html
X2
Not every R/V, nor water heater and plumbing, is the same. One size does not fit all. One has to know what water heater you have and how it is plumbed to properly identify the steps needed to bypass. Pictures are also helpful.
Same with the water filter. Locations are different across models and even some like units. The factory can/will do things differently as they come down the assembly line.
