Wiring diagram
Jaded1
Nov 5, 2023
1
I own a 2020 cherokee 39dl and am having a hard time finding ANY technical diagrams of this beast. Can anyone post a link to the electrical schematics?
None are published
None are published. Most trailers are wired in similar fashion. Tell us your REAL question and we can help you.
From experience and other posts on the forum, likely there aren't any wiring diagrams published. An e-mail to FR Service might get some information.
Good luck
Bob
Welcome to the forum, I see it is your 1st post.
I believe your 39DL is a park model.
There are no schematics available to the general public for any towable Forest River unit. Many have asked but the factory says no.
If you can tell us what you are working on we may be able to help out. For some reason manufacturers do not release wiring diagrams or owner's manuals and such. It took me about a year of back and forth to get the build sheet for mine that showed model and serial numbers for major components. I consider myself lucky because my trailer was 9 years old when I started and many folks have not been able to get the build sheet on newer units than mine.
No wiring diagram? Create your own.
It will take some time and patience but creating your own wiriing diagram/schematic is usually the only way.
Here's an inexpensive tool to help trace wires that disappear behind obstacles. With all power disconnected, 120vac and 12vdc disconnect the wire in question, attach "transmitter" then use non contact probe to find the other end.
"Cable Tracker" from Amazon.
Less than $20.
Electrical Wire Tracer Circuit Test...ls w/Clips & RJ11 Plug https://a.co/d/33Hu1vK
