Yet another wiring diagram/tracing question...
UT_Vol
Oct 28, 2024
27
Roaming
Hello All. I thought I would query the community to see if anyone has an idea where the 2 red wires in the top right connected to the 30 Amp fuse go? I am pretty sure the main red wire connected to the bus bar in the middle goes to the DC side of the WFCO WF-8740-AD. In the second picture the bottom fuse goes to the 20 Amp lead to the trailer jack.
I have read @TitanMike thread on the movement of the items under the trailer to his electrical area.
I have also already re-wired most of the electrical system for my MPPT controller, but for some reason I did not move those wiring connections at that time. Due to a recent incident I must have jarred something loose, who kows? Now I am moving them but I would like to label them or find them.
Where would I look to find the power connection to the Awning in the Forest River E20FBS?
I took a picture of the WFCO WF-3610 Power Pro connections behind the microwave (below), I am pretty sure the Red wire connected to what I have determined to be the WF-3510-B Smart Power Unit is at least 1 of the 2 Red Wires.
The second power unit seems to be the WF-3610-B Smart Power Unit, I noticed this has the Blue DC power supply from the WF-8740-AD F5 - Circuit 5 30Amp Labeled "One Control", which seems to confuse me that part of the system has a direct wire to the Battery but the other part of the system has only power from the DC Distibution Center. There is a second 15Amp Circuit F1 labeled "Monitor Panel". that goes to the 3rd Panel in the WF-3610 Power Pro setup along with some other items. This just seems like it could lead to some odd DC power Behavior depending on what fuse goes bad or connection made??? There are 2 connections labeled "Brake Light" and "WH-DSI" that I am trying to understand what those are?
Anyway if anyone has information that might help please let me know.
